Details of ships and boats
    Re: Details of ships and boats
    I find it very interesting to follow you at your walkarounds on board different ships. Quite fun to see how differently ships can look like below deck.
    More of the same kind of vessels under construction at the yard:
    No pictures from the Pax saloon or Crew Quarters, since I was there to check on her ability to actually perform towage operations, but here is a picture from the sister ship, the FOS Polaris taken at an earlier visit:
    Spacious, with 80 "Business Class" Seats.
    Manifolds in the Engine Room is manually operated:
    Steering Gears:
    Two separate steering gears for individual operation.
    Four Main Engines of 1,920 Kw each (total 10,300 Bhp) driving 4 shafts and Variable Pitch Propellers. Max speed 28 kts.
    Two Main engines in each of two separate Engine Room:
    Main engine (Typical):
    FiFi Pumps are driven by the two Fwrd. Main Engine via front PTO:
    Capacity; 1200 Cbm/hr. each.
    View of aft deck from Bridge level:
    View of deck and Superstructure from aft:
    Although a Fast Crew Boat cum Utility Vessel, this one has a Towing winch:
    Winch Control on the Bridge:
    The spare tow wire reel seen on deck will be stored at the Base where she is working.
    Push fender at Bow:
    Heavy duty Bollard at Bow:
    View of bow from Bridge level:
    Windlass for single anchor.
    View of Bridge from Bow:
    Aft controls:
    View from aft controls:
    Large and spacious Bridge:
    The Fwrd. manouvre position:
    View from Fwrd. position:
    Here is another Crew/Utility Vessel, the FOS Leo (FOS = Fast Offshore Supply) This one is even larger, at 60 m. LOA and was designed and built locally here in Singapore. It is also operated by the same company who built it. It is a Multi-purpose vessel with FiFi 1 and DP 1 class notations.
    I didn't get any good pictures of the FOS Leo externally, but here is her sister ship, the FOS Virgo:
    And FOS Polaris:
    The Bow Thruster is retractable and azimuthing:
    Somewhere down there is the Hydraulic Motor that drive the fixed pitch propeller:
    A similar boat on the breakwater outside Corpus Christie, Tx.:
    That is all for this vessel.
    Next, another Crew/Utility vessel build here in Singapore this year.
    Bow Thruster engine:
    The Engine drive a Hydraulic Pump:
