Details of ships and boats
    Water intake, now out of water:
    Sorry, no onboard pictures.
    A type of vessels that has been seen many times on CVF, but not with much in terms of details and explanation of the complex systems that is incorporated on a modern Live Fish carrier.
    Here is some details for one of the largest and best equipped such ships: http://www.skipsrevyen.no/ms-ro-fjord/
    Here she is as seen in Aalesund yesterday:
    Below deck. The Engine room is in two levels with reasonably good head room and not too cramped:
    Main Thrusters (Niigata Z-peller) with direct shaft drive:
    Niigata Main Engines as well:
    Oily Water Separator:
    That is it from this vessel. Sister vessel will be here early next month.
    Up to the bridge. Fwrd. controls:
    Aft controls:
    Bulk Handling panel:
    DPS-2 Consols:
    Another newbuilding from China which stopped over in Singapore on her way from the building yard to her first assignment, in West Africa.
    The PSV Topaz Armani as seen a Loyang Offshore Base a couple of weeks ago.
    No good external pictures of this one either and cannot find any on the web, but here is specs for the vessel:
    http://www.topazworld.com/~/media/Fi...cs-Sep2013.pdf
    The forecastle deck:
    Unobstructed cargo deck:
    Did I say she was built in Chiana?? So was obviously this crane:
    Everything is new and shiny:
    This vessel has not worked yet.
    The machinery spaces are quite roomy and still very clean:
    Manifolds are manual and colour coded:
    Emergency steering from the Steering Flat:
    A steering wheel is a rather unusual item to find on new vessels these days. Nice.
    Lots of machinery and equipment, but not too cramped below deck:
    Low headroom some places:
    1 set Karmoy stoppers and guide pins:
    350 m.t. SWL is a lot for a small vessel like this.
    View of the winch house, superstructure and bridge from the deck:
    ISPS is well taken care of here:
    Quite a colourful collection of safety devices:
    Emergency escape and protected escape route outside the crash barrier is clear of obstruction:
    Somebody has misunderstood the way Scrambling nets are supposed to work:
    A weight at the bottom of the net is supposed to keep it tight and below water:
    Here the weight has been replaced with a wooden beam. (Common problem):
    It's been a while since I posted any details of ships or boats here. Here is some pictures from an inspection of a new Anchor Handling Tug "Smit Seraya", delivered from the yard in China in July this year and inspected at the Smit yard here in Singapore in Sept..
    I didn't get any good external pictures, so this one is from Marine Traffic:
    View of the forecastle, with windlass and mooring drum:
    The FRC is placed in a single point davit on Port side:
    A 30 m.t. SWL crane is on the Stbd. side:
    This tugger winch hasn't been equipped with a wire yet:
  • Jack Mulder
    Re: Details of ships and boats
    RELATIONSHIP II 02317465.
    Pictures © Ruud Mulder
    As always, it's very interesting to see your quick reportages from the ships that you are visiting Ombugge.
    That machine room seems to be really crowded. A nightmare for maintenance personnel?
    Up close and personal with a Bow thruster:
    Fixed pitch, variable RPM type.
    Stern Thruster drive motor:
    Piping and valves in Dry Bulk room:
    Engine Control Room - Control and Alarm Panel:
    That's all for today.
    Some pictures from below deck.
    Main Engine Tops:
    Bow Thruster compartment:
    Generator Engine:
    FiFi Pumps are attached to Main Engine PTOs:
    Separators, Pumps, Piping and valves in the Engine Room:
    M/Eng. Gear and Shaft Generator:
    Fwrd. Contols:
    Electronic Chart Machine (ECDIS):
    View from Aft manoeuvre position:
    Portable Joystick control on the window sill.
    Winch Control:
    View from Winch Control position:
