Details of ships and boats
    Re: Details of ships and boats
    Ok, Ok, I know, you want to see the Engine room.
    The Main Engines are 1900 Bhp each:
    3 Generators:
    The Electric Switchboard is in the open Engine Room:
    The Bridge equipment is at least a little more sophisticated and up to modern standard:
    But the lay-out does not indicate much understanding of the functions by whoever designed the panels.
    More sophisticated equipment:
    The other half of the fire bucket is on the opposite side.
    When you see electric fitting packed up in plastic, you know they are of high quality:
    A colleague was testing the Emergency Fire Pump:
    Portable Diesel driven pump. (Small ship so this is OK)
    Swing Rope Gantry on either side for Personnel Transfer to other vessel, or to Platform boat landings:
    More for those who like details, especially of towing vessel.
    Here is some pictures from a fairly new Anchor Handling Tug (Built in China 2009). The boat may be new but the level of technology is far from what is found on larger Offshore Vessels built in Europe, or for high end Operators.
    (Some pictures from a sister vessel was shown in the Tug thread earlier)
    No external pictures, since she was moored in the middle of a bunch of other tugs, with a "HK Barge" moored on Port side, but here is at least a view of the deck and superstructure:
    The Forecastle deck with the Windlass:
    No Mooring drums.
    One of the four Anchor Winches:
    Situated below deck.
    One of the Main Propulsion Thrusters:
    The Main Switchboard for power distribution:
    Two RO Watermakers to slack the thirst of nearly 200 people:
    Time for some maintenance during idle period:
    Not too many pictures this time since my assignment didn't call for any.
    View of the work deck from the Bridge:
    And the other way around:
    View from the Bridge is somewhat limited by the Helideck Supports:
    Let me take you on board the pride of the Brunei fleet, the Offshore Support Vessel (OSV) Belite Barakah.
    Built in Malaysia in 2008 and flying the flag of Brunei Darussalam, she is equipped as a Multi-purpose vessel, able to support Diving, ROV, Maintenance operations and pure Accommodation/Flotel role. (191 bunks)
    She has 4-point mooring system and DP-2 Class.
    The Helideck has actually never been used:
    The Pakarang view:
  • Jack Mulder
    Pictures © Jack Mulder
    Jack Mulder
  • pilotdane
    Thank you for the detailed photos. I don't know if anyone else on the board likes so much detail but I certainly do.
    I would hate to be the crew if I ever get aboard; "what does this do?" "what's that?" "can I go in there?" ...
    That will have to do for this vessel. I took a total of 157 pictures for this survey, but that would be a bit boring as much of it was to show condition of individual Ballast Tanks, Cargo Holds and hull externals.
    Ballast Pump # 2:
    Valve Actuator Panel for Ballast System:
    Water Maker. Evaporator type, using waste heat from the M/E Cooling Water system:
    Sewage Treatment Plant:
    No. 2 Starting Air Compressor:
    Aux. Boiler/Economizer with Burner for operation in port:
    Normally using waste heat from the M/Eng. Exhaust.
    Incinerator to burn sludge:
    Not allowed used in port.
    Oily Water Separator:
    Also not allowed used in port.
    Steering Gear:
    Dual Pump Steering Gear power pack:
    Hydraulic Power Unit for Deck Machinery:
