Details of ships and boats
    Re: Details of ships and boats
    Steering gear is very basic, two hydraulic cylinders and a common yoke to three pintles:
    The Steering gear pumps are in the Engine Room:
    An unusual arrangement
    Two Generators are in a separate compartment:
    Surprisingly they are placed athwart ships , not longitudinally as normal. (Not very good for heavy roll, or for list.
    Compressors in the next compartment:
    The Engine Room with 5 Main Engines in a Three / Two configuration:
    One of the Main Engines:
    Out of level since the shaft is slanting. (The propellers are sticking below keel line)
    Main Engine Control and Alarm Panels in the Engine Room:
    No Engine Control Room.
    Jump platform for transfer of personnel to/from Boat Landings by Swing Ropes:
    The Hand Rails are removable.
    This one has an adjustable Jump Platform on Stbd. Quarter:
    Raised and lowered by hydraulic cylinders at each corner.
    Access to the platform when raised looked a little "home made":
    A complete and brand new Main Engine is lashed down on deck:
    It was later sealed and boxed up. To be stored at the base for the next job.
    Crew's cabins and Messroom is below deck:
    The Galley and the proud Chef:
    Even a Washing Machine and Drier is supplied:
    Large Plasma TV and DVD player for entertainment:
    A single toilet is shared with the Master and Chief Engineer who have their cabins at this level:
    Not much for 50 Pax.
    But let us look at the Pax facilities.
    Reclining seats of "Business Class" quality:
    Safety instruction is posted:
    Emergency Exit to the Fwrd. deck:
    Chest Freezers for provision is inside these boxes on the upper deck:
    Chillers are below deck:
    View of the deck from the Pilot House is partly obscured by the MOB-boat:
    A CCTV Camera has been installed to look at the deck from the Fwrd. & Aft positions:
    Aft controls:
    The aft position also have the Bow Thuster control:
    Since it is driven by a separate Engine, the alarm panel for that engine is also here.
    Chart Table:
    The equipment in the Pilot House as it is called, is also very little changed from the original.
    Fwrd. manouvre position:
    GMDSS Station:
    After details from a modern MPSV let me introduce you to an other type of vessels widely used in the Offshore Oil & Gas industry, the Crew Boat cum Utility Vessel.
    These vessels were first developed for service in the Gulf of Mexico in the 1960s. Their purpose was to carry crew and light supply to/from the rigs and platforms, which was all within a relatively short distance from shore at the time.
    Over the years they have become larger but with little change in basic design and equipment, unlike the original Supply Vessel cum AHTS, which was changed when European, especially Norwegian yards got into the act.
    Originally the standard Crew Boat was built from aluminum, 60-70 ft. long, with two engines, fixed pitch propeller and two spade rudders. As they grew larger the same basic hull form was maintained, but to keep the speed at around 18-20 kts. an additional engine and propeller was added. Larger still? Add more engines, propellers and even rudders.
    The one presented here is 170 ft. (52 m.) long and has 5 Main Engines, 5 propellers and 3 Rudders. Otherwise it is much the same as the original GOM Crew Boat. Built in the US in 2000 and originally US flag.
    Her she is at a small shipyard in Singapore:
    Client's Position Surveyors have their own dedicated space on the bridge:
    "Sunken" office space on the Bridge:
    More office space:
    That should suffice to show what one of these vessels looks like from the inside.
    Port chair aft:
    Cargo handling, Stability and Anti-heel control panels on the right hand side.
    View of Work deck obstructed from aft position:
    (Hence the CCTC screens up high in the last picture)
