Re: Details of ships and boats
Let us start the trip down from the bridge to below deck.
The Muster Deck is at Level 7:
From there it is a bit of a climb to get to deck 6: (At least on Port side)
The next level is almost blocked by parts of the Diving Spread:
This is what it looked like before the Diving Spread was installed:
Finally we get below deck.
First to a large Store Room at Tween Deck Level:
This is as it looked in April, 2010. Now filled with Dive Gas Cylinders.
Access between compartments below deck is by watertight doors:
Hydraulically operated. (Small handle by pump, large handle manually)
Status of doors opened/closed are displayed on the Bridge and in the Engine Control Room.
This vessel has Diesel/Electric Propulsion, hence there are no Main Engine(s), only Generators.
5 x Cat 3516TA, 2100 kW each
On my last visit there were a problem with exhaust leak:
Awaiting spare parts and a maintenance period to effectuate repairs.
+ 1 x Cat 3508B, 1,700 kW:
There is also an Emergency Generator of 160 kW (No pics)
Power distribution is via the Main Switchboard:
Stepped down to 440V and 220V / 60 Hz for domestic consumption.
690V main power for propulsion is distributed via Variable Frequency Controls situated in the Thruster Rooms:
2 x Main Thrusters, Azipod 120, 3000 kWe each:
Fixed Pitch propeller, variable speed (RPM)
Steering Gear is incorporated in the Thruster assembly:
Driven by separate Hydraulic Power Units with dual pumps:
Emergency Operation of the Thruster pods is possible from the Thruster Room:
Now to the Bow Thruster Room:
2 x 1,300 kWe Tunnel Thrusters + 1 x 1,200 kWe Retractable Azimut Thruster.
The drive unit of the retractable part:
Coupling on the fixed drive motor:
No leak at the glands:
Variable Frequency Control:
Some of the auxiliary equipment found in the Engine Room and other machinery compartments.
Air Compressors:
Water Makers:
Evaporator
Reversed Osmosis
Pump Room:
Manifolds:
Remotely operated from the Bridge and/or ECR.
Fuel Meter:
Oily Water Separator w/15 PPM Alarm and Auto stop:
Boiler (For heating purposes only):
Incinerator:
Oil Spill Kit:
Remote and Manual Fuel Shut-off at Day tanks and Settling tank:
High Pressure Washing system:
Piped throughout the vessel.
Mechanical Workshop:
with Lathe Machine:
And finally, the Engine Control Room (ECR):
That should be enough details from one ship, even for the self-confessed "detail freaks" among the CVF members.
PS> Majority of the pictures are from April, 2010, only some from the recent visit to this ship in Chiwan, China.
In contrast to the near new and highly sophisticated CSV Normand Clough, here is another vessel servicing the same basic purpose, but in shallow waters only.
May I present details of the Support and Accommodation vessel "Trinity Revival", originally built as the Japanese Research Vessel "Kaiyo Maru" in 1976. Since then she has had several owners; 88 GSI MERLION - 93 MERLION - 03 SARKU SIPADAN - 08 TRINITY REVIVAL.
Pictures are from Oct. 2009 at Eastern Anchorage, Singapore.
External view:
Anchor Winches Fwrd.:
Stbd. aft Anchor winch:
Foredeck with hatch to Cargo Hold and a new crane installed:
View along Stbd. side:
View along Port side:
Bunker tanker alongside.
Work Boat on Stbd. side missing:
Replaced with this one on Port side:
Gangway for transfer to Platforms:
Boarding Platform at stern:
With Swing Ropes Gantry for transfer to Crew boats, or direct to Platform Boat Landings:
View along the deck from stern:
Deck crane:
Hydraulic Power Unit for deck crane situated on open deck:
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
